OneUI6 quick settings panel need refinement with opening and closing actions.
(Topic created on: 12-11-2023 03:06 PM)
Sukumar002
This issue is specific to those who use dual sim.
When multi sim info is set to show when quick settings is expanded it requires two swipes to close the quick settings panel.
If the layout is used well, this would eliminate the need for double swiping to close it.
The actual cause is the scrollable area due to quick settings panel elements completely occupying screen.
I propose two ways of doing it:
1. Enable user to customise the quick settings square to a rectangle so only two rows appear at any time like how Quickstar allows customising the number of columns.
2. Resizing the tiles and allowing user to choose which elements to show in the Quick settings.
I am open to a conversation or discussion on this if someone from Samsung really care about customer feedback.
2 Comments
cs_member10
Dear Samsung Member,
As per your query, we request you kindly share the log file. Without a log file we cannot analyze this issue, Also share video clips and images for better understanding and report this issue with the log file. This will help us to further investigate and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Sccott
Hey bro, Finally Today I got the solution And i wanna share it with you...
First Download "Goodlock" App from Store And Then Download "QuickStar" and Enable the QuickStar And Booom!!
Now your Problem Will ve solved....
If you still have any issue Just Let me Know....
