ONE UI 7.0 Battery drain issue
(Topic created on: 6 hours ago)
sunith5
Beginner Level 5
 After update s23 One ui 7.0 battery drain issues facing..
4 Comments
deypriyam
In the battery drain case , there are multiple reasons behind it.
You cam send an error feedback form to Samsung . they can surely reply.
I also send them error feedback form as I am facing same problem on my A35.
If you think this will help you , please consider my comment as a solution by clicking on the three dot and click on accept solution 🙏 🙏.
jlocatell
check instagram / threads apps and if you dont have a pending google play update
BiRdMaN
ShAMeSUNG will fix it in the next security update
BiRdMaN
Yes, many users have reported experiencing similar problems. This can be due to the phone re-optimizing itself after the update or apps needing to be optimized for the new firmware.
Add apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
