Notification problems
(Topic created on: 06-24-2026 06:54 PM)
dv_ptl12
Guys any fixes
I have reset my whole setting and all
Removed or deleted Goodlock apps and done more but this notification stuff has no fix
Samsung please do something
I like my ui being clean so
18 Comments
PixelTech
Yes bro .. btw which device? Most of the S series have received One UI 8.5
dv_ptl12
Got s 25 ultra bro and I had also opted for 8.5 beta too
PixelTech
Excellent device choice 💯 .
(Maybe it's issue because of beta version? )
I received one ui 8.5 on my S24fe with no issue ..
dv_ptl12
Yeah I was waiting on 9 but I opted out for now until this issue is solved
PixelTech
Ooh
avtarkmu
Reset
avtarkmu
cs_member10
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
dv_ptl12
Done it the reply was go to support and choose appropriate option.
