Notification Sound Issue
(Topic created on: 01-30-2017 11:34 PM)
rehanzaveri
After Updating My Samsung S7 Edge to Nougat, there is no notification sound from some apps
i have tried each and every option bt still cannot find a solution to this problem
3 Comments
MrAwesome
try resetting your divice
salmanhussain
yes reset or just restart
Samsung_India_
Thank you for sharing your concern and feedback. We would like to inform you that kindly once check device notification setting under option setting of the device.
