Notification Panel Problem
(Topic created on: 01-25-2018 02:33 PM)
JayeshK
Notifications are not showing on notification panel.Please refer attached screenshot.55f05fae-ecd6-4149-96f4-1a3df285b96b.jpg
4 Comments
ShameerAhamad
if you get any notification then only it will show
JayeshK
U dumb,i am using phone since 8 years so i think i have that much logic.😒i had lots of notification then only clear all and block notification options are showing on notification panel.
CoolRP
Reset app preferences from settings😊
admin_
Thanks for being a part of Samsung community. We would like to inform you kindly follow the steps below to resolve your concern:-
- Navigate to apps >> Settings >> Apps >> Tap on three dots >> Reset app preferences.
- Please run your device in safe mode. If you are getting notification in safe mode then there may be a third party app or other program that may be leading to what you are experiencing. Kindly uninstall the recently downloaded third party app and check the issue.
- Please do reset your device on factory mode after taking the data backup Via Smart switch.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
Be sure to hit ♡ when you find an answer that works for you.
