Not displays mobile network signal indicators for a device both 5G and LTE
(Topic created on: 02-24-2025 10:58 AM)
Yousufw
Samsung Galaxy S 25 Ultra not displays mobile network signal indicators for a device utilizing both 5G and LTE (4G) connections.Also Now bar not working properly.Please resolve both issues in next security patch update.
Regards
Samsung Galaxy S 25 Ultra user
4 Comments
ITS_DIPU17
Runing softwere One ui 7?
Ultra_Devil
In S25Ultra one UI 7 already pre installed..
Ultra_Devil
Bro check your quick star app if you have hide icons, also now bar works fine, but if you are talking about it goes off from the lock screen when u open it, so it's how it works..
cs_member10
Dear Samsung Member,
As per your concern, we want to inform you that the Now bar feature allows you to display information such as live notifications, music, or modes and routines on the lock screen. The Now brief feature provides a personalized briefing with suggested content and actions that change throughout the day.
The Now bar can be customized which item to show through live notification apps enabling, music player, current mode on the lock screen.
To customize the Now bar: Settings > Lock screen and AOD > Now bar > tap ‘View more’ to see more on Live notifications > Tap the switches to enable app notifications.
To use: Double tap the screen or press the power button to wake the lock screen > swipe upward on Now bar area to move to the desired bar > tap the Now bar to open the expanded view, press and hold the Now bar to open more options to remove it or change the settings.
However, kindly visit this mentioned link to resolve your issue by using the below-given link regarding network signal issue.
● Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
Additionally, We are taking your feedback regarding this matter and will take it into consideration for future updates.
