Not able to connect Bluetooth to Maruti Ertiga
(Topic created on: 11-25-2017 09:14 AM)
atitS8plus
Beginner Level 3
Hello,
I tried connecting my Samsung S8+ to my car -maruti Ertiga via bluetooth..but I am not able to connect. Maruti Ertiga bluetooth name doesn't appear when I searched via bluetooth..
please help
4 Comments
admin_
Thanks for being with Samsung and sharing your concern. We would like to inform you that please restart your device and try to search also would like to tell you please reset the Bluetooth settings of your Car and try again. Be sure to hit ♡ when you find an answer that works for you.
atitS8plus
Beginner Level 3
I had restart my mobile..still not able to connect....is there software glitch??
atitS8plus
Beginner Level 3
awaiting ... issue not yet solved
That is not a mobile problem .
Click the bluetooth button that was located in your stearing . Then click pairing then you can connect ..or ..search in youtube (bluetooth not working in ertiga)  u will get a demonstration
