06-14-2018 12:17 PM in
06-15-2018 02:24 AM in
Galaxy S- Mark as New
06-19-2018 09:17 AM (Last edited 03-14-2019 04:04 PM ) in
06-23-2018 06:22 PM in
06-16-2018 02:53 PM in
Galaxy S1) Ensure that network frequency of your device should be selected on Auto-mode.
Menu>Settings> Connections>More Networks> Mobile Networks> Network Mode> Select Auto mode (GSM/WCDMA/LTE).
2) Search for the Network Manually by the steps as mentioned:
Menu> Settings> Connections>More Networks> Mobile Networks> Network Operators> Select Manual Search.
3) You may check by exchanging the SIM in SIM slots.
4) Insert different SIM card in your mobile and check if the issue is resolved or not.
If still issue persists then we would suggest you to once contact with your service provider.
Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
07-04-2018 11:13 AM in
08-09-2019 02:13 PM in
12-03-2019 10:31 AM in
Galaxy Sthe phone is **bleep** without the noise cancellation option. i have a big problem using my S9 plus since everyone keep complaining about the background noise. we demand this to be fixed ASAP
06-29-2020 04:09 PM in
07-18-2020 04:21 PM in
