New S23 fe battery drain
(Topic created on: 05-24-2024 01:45 AM)
Elsayed_Eltantawy
I bought new S23 fe as the samsung posted in the phone specification that battery is very good and take up to 19 hours to come empty, this is at least case, unfortunately Now in my new phone not complete 4 hours from full charge, I wasted my money to buy this phone, and not buy any phone from Samsung again !!!!
4 Comments
Jayster
I get around 6hr of SOT in my ultra the battery doesn't last for a day unless you don't use the phone at all. This is on WiFi if it's on data I get same time as yours 4hrs
Zammi
It will take about 2 weeks to stabilize. But overall I have seen people are complaining about battery drain since One UI 6.0 / One UI 6.1 updates.
You can try something:
Open settings and search for 'Adaptive battery' and disable it.
Samsung_specialist
To address the battery concern, we recommend performing additional troubleshooting steps to identify the root cause of the issue. These steps may include:
1. Update Software: Ensure that your device's software and related apps are updated to the latest version. To update your mobile device's software, follow these steps:
   - Step 1: Go to Settings > Software update.
   - Step 2: Tap on Download and install.
   - Step 3: Follow the on-screen instructions.
2. Setup Phase: Your new phone’s battery may initially drain faster as you set up applications and features. This is part of the setup phase, and background operations are optimized during this time. Allow a few days for all background operations and syncing to complete.
3. 5G Service Impact: While connected to a 5G network, your phone may consume more battery than usual due to the high-speed processing of large-capacity data. Consider optimizing overall usage and adjusting background usage limits.
4. Optimization Steps:
   - Open Settings > Battery and device care > Optimize now.
   - Adjust Background usage limits: Settings > Battery and device care > Battery > Background usage limits.
5.  Use adaptive battery: Settings > Battery and device care > More battery settings > Adaptive battery.
If you have attempted these steps without success, we kindly request you to visit the nearest service center for a physical inspection of your device. You can locate your nearest service center using the following link: (https://www.samsung.com/ae/support/service-center/
A018
New phone Samsung s23 fe battery backup bad, Battery drain, international version
