Network problem
(Topic created on: 10-06-2025 06:23 PM)
ARansa
After one ui 8 network problem multiple times i posted but no solution
6 Comments
Vishwa1301
Try turning off auto blocker from settings, if network appears after turning off auto blocker, switch to basic protection or something like that in auto blocker
RedBullRussia
Have you tried all the troubleshooting steps?
Dahalhari
I have faced the network problem when updating my Galaxy S24. I switched off whole night and when I switched it on next morning, Interestingly the problem solved.
s23_ultrabd
Comment on Tarun Vats X
cs_member10
Dear Samsung Member,
● Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
bigthinker
Same here a06 5g 😂
