Network problem
(Topic created on: 09-13-2025 02:53 PM)
mdtahir
My phone network not work properly 5g but 4g work ok i check all settings but problem same
3 Comments
Kuldeep_Rvl
Turn on always on 5G then it will not switch to 4G
Punitsachdev
Which sim you are using?
cs_member8
Dear Samsung Member,
Thank you for reaching out to Samsung Customer Support. We appreciate your concern and would like to assist you in resolving your issue.
● 5G in your Galaxy device: https://www.samsung.com/in/support/mobile-devices/how-to-use-5g-on-your-galaxy-phone/
● Network optimization: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
Note: kindly contact your network service provider once to make sure there is no issue from their end.
In case the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
