Network problem
(Topic created on: 05-19-2025 07:34 AM)
aaashiiieee
After updating to UI7 android 15 my phone network is not stable. Facing lot of issues in calls and mobile data
5 Comments
Wodehouse
Reset network settings.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
aaashiiieee
Already did, but no use
Anupam06
Thanks for informing 🙏
Shonzzzz
cs_member10
Dear Samsung Member,
As per your concern, we would request you to kindly visit this mentioned link to resolve your issue.
● Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
