Network problem
(Topic created on: 12-25-2023 02:26 AM)
shalini0925
After the last update for samsung galaxy s23 i m facing network issue for my jio sim.
My 5g internet is working smoothly but i neither able to make and receive calls nor sms.
When ever i m calling its showing no mobile network and calls get ended. Also the volte feature for jio sim is not showing in the setting.
Anyone else facing same issue
3 Comments
optimistak
Well I have also update to December security patch but not having the issue mentioned by you can try removing jio Sim & cleaning it's contacts using a soft eraser and insert it back. If that also don't help try to get a new Sim.
cs_member10
Dear Samsung Member,
As per your concern kindly visit this mentioned link to resolve your Galaxy device network issue and if you had updated your device in One UI 6 then you have the VoNR feature, our team is working on it, you will use the Vonr services soon kindly be rest assured : https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
In case the issue still occurs kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Pavandivvela
Even same for me ..but with Airtel sim ...it's not even getting midrange mobile kind of network
