05-11-2024 12:11 PM in
Galaxy S- Mark as New
05-11-2024 03:05 PM in
05-11-2024 03:25 PM (Last edited 05-11-2024 03:27 PM ) in
05-11-2024 04:19 PM in
Galaxy SDear Samsung Member,
As per your concern, we would request you to kindly perform the following steps to resolve your issues.
Galaxy device internet issue: Check Mobile Network: Settings> Connections>Mobile networks> Network mode> Select 5G/LTE/3G/2G (auto connect).
Check Network Operator: Settings> Connections> Mobile networks> Network operators> Select automatically.
Check Data Roaming: Settings> Connections> Mobile networks> Data roaming to enable it, if disabled.
Reset network settings: Settings> General management> Reset> Reset network settings> Reset settings> Unlock your screen> Reset.
Check another network operator SIM: If the issue has not been resolved, then get in touch with the network operator and try to check with another network operator SIM.
Note: kindly contact your network service provider once to make sure there is no issue from their end.
Galaxy device Camera issue: Reset the camera settings: Home screen tap on Camera>Settings>Reset settings>Reset.
Clear camera application data: Apps>Camera>Storage>Clear Data
Check app cache: Settings > Apps > Camera> Storage > Clear Cache.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
