Resolved! Solved
Netflix not supporting high resolution and HDR on S10Plus ?
(Topic created on: 02-01-2021 08:51 AM)
bharatshaan
Hello All,
Below is the screenshot of my Netflix app and it shows no HDR support and L3?
Why?
mudassarfa
its a bug with Netflix app. if you download any movie from Netflix and login on another phone with the same ID it messes with the DRM license. only solution is the reinstall the Netflix app and you will be able to view the video in HD and u will get back the l1 certification
14 Comments
prit_3008
please check this must in display settings screen resolution
prit_3008
then select wqhd+
prit_3008
if you got solution then please please accept solution
click 3dots at right side of comment then accept solution please if you got your answer
bharatshaan
I already use phone on QHD+
prit_3008
i think that depends on plans of Netflix
bharatshaan
I use highest plan
vicke
depends on which plan ur using ..... also after pandemic all video quality resolution got decreased because data should not consume much
prit_3008
no brother now that policy disabled;because i got 1440p 60fps hdr on youtube
vicke
I have checked my Netflix and it shows max resolution full HD and HDR compatible HDR 10 .... did u update ur Netflix to latest
