Need help
(Topic created on: Friday)
vsthar
How can I lock the notification bar when the phone is locked?
S25+
5 Comments
arunyadav1199
Go to lock screen and then select notification turn off it
vsthar
Notification is off
But the panel is still visible how i disable the panel itself when phone is lock
raalapas
In Samsung you can't hide quick menu panel, if device is locked then no one can play with you wifi, Bluetooth, Hotspot, location, quickshare etc except volume, brightness torch and basic stuff, it require screen to be unlocked anyways.
Just enable below option from settings
Lock Screen and AOD > Secure lock settings > lock network and security
vsthar
Thanks
mylala123
I am unable to pair a new Bluetooth device
