Need help in video setting
(Topic created on: 07-22-2025 12:04 PM)
Akshitv
Hi I'm using s24+,
When recording the video if in start I set the 2X zoom then in between the video I'm unable to change it to 1x or .5x
4 Comments
Radhubhat
Check with resolution, in 8K mode it won't allow
Akshitv
Okay thanks I was shooting with UHD 60 fps and it was getting the same error when I switched to UHD 30 fps it allowed me to change the zoom setting in the video
Radhubhat
Restart the mobile and try again
cs_member10
Dear Samsung Member,
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
