Need Help
(Topic created on: 01-28-2017 11:09 AM)
Sachz
Hello everyone.
I need your help.
after updating my S7 Edge to Nougat
even if my screen is locked one can still scroll fingers to access the notification bar at top because of that one can easily change the phone settings like Brightness, sound/vibrate, wifi on off, mobile data on off etc..
how to disable in locl screen ??
any solution for this guys ??
11 Comments
Enelrev
Well that happens on my S7 Edge too; something that should not be allowed. Hope Samsung rectifies this.
However you can prevent someone from accessing and changing the settings by activating security lock features with either a fingerprint or PIN.
Sachz
fingerprint lock dint help.
Hope samsung is listening to rectify this issue.
Enelrev
Fingerprint lock works on my S7 Edge.
samlove
well that is a good thing that you can access quick settings from lock screen. i dont think its any kind of issue...its a sw designed to do so. because most of the time u r in hurry and without even unlocking the phone u can toggle the settings you want. hope u understand my point.
Enelrev
I guess so too with security feature to unlock.
shafiqsm
true
dipsync
By keeping this feature you are not at all compromising your security. This feature isn't newly introduced in Nougat but exists from Android M. And idk why you can't agree on liking this feature. Supposedly if you want to put your cell on vibrate in an urgent situation would you want to go through all the locks and then scroll down to silent your phone or rather open the notification bar from the lock screen itself. Only the things which dont put you at a privacy risk are available in the notification toggle. Things which need to be secured will ask a password when tapped on it. So don't worry and please don't ask for unnecessary features.
Sachz
yeah thats true.
some one can easily turn off mobile data, turn the phone silent and rob the phone which will b difficult to track
Samsung_India_
Thanks for being with Samsung and for sharing your feedback. We have noted down your valuable feedback and we will surely share this with our relevant department, any update in this regards will be convey to you via various means of communication.
