Need Help Creating a Call Forwarding Routine for a Specific Time
(Topic created on: 08-03-2024 08:24 AM)
sippy316
Hi everyone,
I'm looking to set up a routine on my Samsung phone to automatically forward calls to another number at a specific time each day. I've been exploring the Bixby Routines feature, but haven't found a straightforward way to do this yet.
Ideally, I'd like the routine to:
Trigger: Every day at [Your Desired Time, e.g., 10:00 AM]
Action: Enable call forwarding to [The Phone Number You Want Calls Forwarded To]
(Optional) Action: Send me a notification that call forwarding is active
8 Comments
Oldy4756
Sorry sir but this forwarding feature is not present now. Mind giving them feedback for same to include in future updates.
sippy316
Ok thank you
RĀJ
Such an optionption is not available as of now in routines, but your idea is good
sippy316
thank you
cs_member10
Dear Samsung member,
As per your query, we want to inform you that as of now, this feature is not available on Samsung devices. We have noted your feedback regarding the same and we are continuously working to make our products better and more efficient.
sippy316
Thank you so much, we need this badly 🙏
sippy316
ok
iamshehi
Hey, exact option is not available, but I can suggest a way to achieve this.
You can set call forwarding to a specific number when unreachable. Then set a mode or routine to make your phone's airplane mode to turn on on the specific time you need.
Hope this works for you.
Thank you.
