Resolved! Solved
NOT APPLICABLE
(Topic created on: 01-21-2021 09:59 AM)
prit_3008
I have active level 6 and this is now going to not applicable any solution please 🙏🏻send me 😢
Anantg11
it is not only with u, but everyone
I was also shocked after seeing this...
10 Comments
prit_3008
you have also same problem brother see
prit_3008
its a bug it will fix in some time
Brother its a bug and it will be solved soon. Don't worry.
prit_3008
its done bro its now showing
Server issue.
prit_3008
yaa its now fixed
Rohitvpathak
It's a bug.. Wud be sort out soon
prit_3008
yaa it's fixed
Anantg11
