My S25 Ultra camera lens has a lag issue when using zoom.
(Topic created on: 03-21-2025 02:30 PM)
Nitinp
When I use the camera on small objects and use the zoom option, I find camera lag and lens issues.
2 Comments
cs_member10
Dear Samsung Member,
At Samsung, we always aim to provide impeccable services to our customers, and we highly regret that you feel this way.
Please follow these easy troubleshooting steps which may help in resolving this issue:
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
rahulk
Updates देने में Samsung apple se काफी पिछड़ रहा है हर ब्रांड में updates time per aa rahe hai per samsung apne lag hi nahi sudhar pa raha hai
