Misalignment Between Display and Aluminum Casing on Samsung S22 5G
(Topic created on: 09-18-2024 08:52 PM)
ZamanHassan
Hi Samsung Team,
I’ve been using my Samsung S22 5G since January 2023, and while I’m overall happy with its performance, I’ve noticed an issue that concerns me. After purchasing the phone, I observed a slight misalignment between the display/back glass panel and the aluminum casing—there’s a small gap that doesn’t seem normal.
Attached image for reference.
I wanted to check, whether this could be a manufacturing defect, or anything else?
Looking forward to your guidance.
Thank you!
Front Side
Back Side
cs_member10
Dear Samsung Member,
As per your query, we would request you kindly visit the service centre and inspect your device with the technical team end, they will provide you with all the information in a better way after inspecting the device physically.
You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
