Microphone problem
(Topic created on: 10-29-2025 11:22 PM)
sarveshthakur
There is a glitch in microphone of some mobiles my mic not working during google mic ,recorder,chatgpt mic,youtube mic and Etc i generally prefer to search with using mic but the mic not respond anything to me. Please have a look this issue it is not only in my s23 fe but also In my some friends mobile Please have a look hear @Samasung .
Over all i am using my phone since 1.5 years it wasn't lag and good software, good camera etc overall phone is excellent but there is a problem regarding to the microphone
2 Comments
cs_member10
Dear Samsung Member,
● Disconnect all accessories: Disconnect anything plugged into the headphone jack like, a selfie stick, headphone, Bluetooth, etc.
● Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device.
● Restart the device: Press & hold the power key>Tap on Restart>Tap again to Restart your phone.
● Record your voice without using headphones by using a voice recorder" and playing the recorded audio:
Step 1: Navigate to the apps screen and tap on the Samsung folder.
Step 2:Tap on Voice Recorder.
Step 3: Tap on recording to record your voice then tap on Stop to save the recording.
Step 4: Tap on Save.
Step 5: Select and tap on recently recorded audio to hear the audio quality.
Note: If the recorded audio quality is good, then your microphone is working fine.
3. If you do not remember, then advise to reset (Forgot password) his/her Google account.
Path: Settings> General Management>Reset>Temporary cloud backup or External storage backup>After backup tab on Factory data reset to reset your device to its factory default settings.
In case the issue still occurs please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
pranavg007
Beginner Level 3
i am facing the same problem
