Media Volume going to Maximum by itself
(Topic created on: 11-12-2017 06:29 AM)
Shuchita
I am using s7 edge and facing the problem of media volume going to maximum just as an sms is received. Every time the phone receives an sms, the media volume goes to maximum no matter what my previous setting was. If i am listening to music or watching any video, it causes a lot of inconvenience all of a sudden.
5 Comments
Addyzaccount
factory reset maybe?
Shuchita
have already tried that. problem not solved
admin_
Thank you for your query. The relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
Shuchita
i got a reply from samsung support on this issue.
problem solved now.
it was recommended by support team to run the mobile in safe mode to know if its a third party affecting media volume. It was just that. No issue faced in safe mode. Since its difficult to pinpoint the third party app since there are so many on the phone, i revoked message permissions to almost all of third party apps. (in settings?
Shuchita
so glad to be able to get in touch with samsung support and samsung community on any issues faced
