Major Battery Drain on S25 Ultra After May 1 Update – Anyone Else?
(Topic created on: 2 weeks ago)
shreyasdy69
After updating my Galaxy S25 Ultra with the May 1 security patch, I’ve noticed a major battery drain issue. My phone, which easily lasted a full day before, now struggles to get through half a day even with minimal usage. This is seriously affecting my daily usage, and it started immediately after the update.
Other changes I noticed:
Battery icon is now bigger.
Spotify playback appears in the notification bar, similar to the dynamic island on iPhones.
These UI tweaks are fine, but the battery issue is huge and makes the update feel like a downgrade.
Is anyone else experiencing this? Any solutions or fixes?
Please let me know this is really frustrating!
Thanks in advance!
4 Comments
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
shreyasdy69
Basic troubleshooting like disabling Wi-Fi, Bluetooth, or auto-sync is unacceptable for a flagship device. These problems, starting post-update, demand an OTA fix, not workarounds. Please release an update to resolve this promptly and restore the premium experience expected. Error logs shared via Samsung Members app. Current experience: 1/5 stars.
