Lockscreen widget problem
(Topic created on: 12-04-2025 12:57 PM)
Abhisingh04
Samsung S24 Ultra lockscreen widget keeps healing by itself what should I do
7 Comments
goodthings
Please reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time also optimize your's device in device care too also clear cache of all apps manually also update your's all apps too then try to it's again. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
Abhisingh04
This will delete all my data?
goodthings
No. It's a simple reset in general management settings. It's not a factory data reset. So please don't bothered about this issue. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
vinayshah
Expert Level 4
Don't believe this guy. He's made almost entire forum members hard reset their phones. He's some **bleep** who keeps copy pasting same reply all over the platform.
goodthings
You're welcome to here.
vinayshah
Expert Level 4
BTW, there r 2 types of resets, 1 is soft & the other one is hard.
U can perform soft reset 1st and see if that works for u.
Abhisingh04
Tried everything, it didn't work
