LED Notification Lights.
(Topic created on: 03-24-2021 10:12 PM)
dos5745
Led notification is reqlly possible in s20 series and even many other samsung phones.
Samsung needs to really wakes up for this.
How the white light rotates around front camera while camera is searching for the face. Same way the led notification lights of different colors app wise can rotates on the same camera until the user see the notification. it will use very less power and combined withbedge light.
 LED colors can be customized as per app settings. please samsung do this..it is very important and required feature for smart phone.
5 Comments
No led light in that device
souravKhan
You can use "Always on Edge" app from Play store to get LED notification light.
Other than that there is no other option.
assist4tech
If you want you can turn on Edge lights or there is an app that let's you turn on ring around the camera as a LED notification.
dos5745
Edge light will blink and stop but this is about when we are not in front of phone. Continuous blinking will help us about recognize notification with app wise light.
It was coming in old phones
assist4tech
That's old style Edge lighting. Edge lighting now has new features. Also try Hole Light from Playstore. Try this
From Settings (app icon or cogwheel in notification bar), tap Notifications > Brief pop-up settings > Edge lighting.Tap Lighting style to customize the color, effects, width, transparency and duration of the Edge lighting.Tap Color by keyword to configure a smart lighting effect triggered by specific text in notification titles and body.Tap Show Edge lighting to choose whether it replaces notification pop-ups when the screen is on/off/both.Tap Choose apps to pick those applications that can activate Edge lighting when a notification is received.Turn on the Show even when screen is off setting.Tap Done when finished
