Issues need to fix πŸ™
(Topic created on: 02-21-2024 09:40 PM)
CHANU_99
Some minor issues but facing always.. need to be fix πŸ™
This is Galaxy S21 FE 5G (Snapdragon 888).
Facing issues:
1. 3x telephoto lens can never focus close subject. This is working only for subjects which are far away.. If I try to focus close subject, it shifts to the main sensor or if I tap on 3x to focusing close something, it never shifts. (It's after UI 6.0) {may be this is happening on most of the S series phone having telephoto lens}
2. Selfie camera gives blurry output. If I take a group selfie, only my face is sharp & clear.. but all other's face at my background (if in little distance) are so blurry & not sharp. Also for scenery background.
3. Eye Comfort Shield never works on Lockscreen. When I unlock, it works but never on Lockscreen. (It's after UI 6.0)
4. Phone hangs/heavily drops frame while remastering a picture in gallery. Remastering animation not remains smooth & if I scroll down notification panel, it feels like 90's phone with heavy load.
5. Last 5% charge drops within 1-2min while in use.
I hope @Samsung look into these matterπŸ™
31 Comments
AJAB_MORIA
When did you do a factory reset?
CHANU_99
26th December, 2023 i.e not completed 2 month yet.
AJAB_MORIA
Now you have to wait, upcoming bug free updates.
CHANU_99
Yah! That's hope now
muhammadmpp
Device Now running In February Security patches
CHANU_99
Yes
muhammadmpp
Clear cache your phone
muhammadmpp
Try this
