Issue with fingerprint sensor
(Topic created on: 12-01-2025 09:48 PM)
imanojchoudhari
I have Samsung galaxy s24 ultra i am facing low accuracy in fingerprint sensor i am very disappointed in a flagship this type of sensor used when i unlock my Samsung galaxy s24 ultra then i need to cover full fingerprint sensor and need to hold my finger for longer to unlock the device some time my device not reconige it's my finger i increased touch sensitivity but still facing same problem
4 Comments
cs_member10
Dear Samsung Member,
At Samsung, we always aim to provide impeccable services to our customers and we highly regret that you feel this way.
Please follow these easy troubleshooting steps which may help in resolving this issue:
● Ensure that your fingers are clean and dry.
Note: If the skin on your fingertips is peeling or cracking, or your fingerprint is difficult to capture, the fingerprint ID on your phone may not work.
● If your fingerprints fail to unlock the phone while the phone is recharging, remove it from the charger and try again. If you are charging the phone with a charger and data cable from other brands when you use fingerprints to unlock the phone, they may interfere with the fingerprint sensor and cause the recognition to fail.
● Clean the fingerprint sensor with a soft cloth. Make sure the fingerprint sensor is dry and free from any debris that may cause the sensor to be unable to recognize the fingerprint.
● Remove the current fingerprint and set up the fingerprint again. When you touch the sensor to set up a fingerprint, make sure you set the entire fingerprint, including the outer area of your fingertip. Setting the entire fingerprint area enables successful fingerprint recognition with any grip.
● How to remove Fingerprint: Path: Settings> Biometrics and Security> Fingerprints> Fingerprint1> Remove> Remove again to confirm.
● How to Set up Fingerprint: Path: Settings>Biometrics and Security> Fingerprints> Fingerprint> Scan your fingerprint> Place your finger on the sensor, then lift it off when you feel a vibration> Continue> Reposition your finger each time to capture the edge of your fingerprint> Done> Fingerprint added successfully.
● Try Safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
3. If you do not remember the password, then advise to reset (Forgot password) your Google account.
Path: Settings> General Management>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
I already try all the steps still fingerprint sensor is slow in Samsung improve it in upcoming updates
I need to place full finger on sensor to unlock device and 0.5 sec delayed to unlock
I need to press finger multiple times to reconige
