Resolved! Solved
Issue with Camera Lens Switching on Samsung S24 Ultra
(Topic created on: 12-07-2024 06:22 PM)
VD22
I am experiencing an issue with my Samsung S24 Ultra camera while capturing images through a microscope. The phone's camera frequently switches between lenses (wide, ultra-wide, or telephoto) automatically, making it difficult to take consistent and clear photographs.
vis07
In camera assistant settings, turn off Auto lens switch options
11 Comments
mohithashmi
Phone ko restarts karo problem solve ho jayega mere sath bhi aaisa hi hua tha
VD22
Vo to check Kiya aur week me ak baar restart ho jata he
vis07
VD22
Where can I find this option .pls guide step by step 🙏
vis07
Are you using 'Camera Assistant' module in Good Lock application?
If Yes, in your Camera settings you can find 'Camera Assistant' option.
VD22
Ohk I have to download app from good lock application
Disable the automatic lens switching feature in the camera's assistant settings.
Please kindly acknowledge this solution by clicking the three dots and selecting "Accept Solution" if you find it helpful. 👍
Thanks,
DP
mohithashmi
Any one tell me my s24 ultra scratch inside charging port
vis07
Please use original or certified charger cables to avoid damaged. ⚠️🔌
I hope still your device is under warranty. 📞👍
Reach Samsung Care to change the charging port if required. 💡🔧
