Issue while connecting USB through OTG
(Topic created on: 10-09-2024 04:16 PM)
_parthmanhas
Hello, I need help with my Samsung Galaxy S21 FE. When I connect a USB drive using an OTG adapter, the phone doesn’t seem to detect it. Any advice on how to get this working would be appreciated. Thanks!
2 Comments
cs_member10
Dear Samsung Member,
1. Check different OTGs with your device.
2. Check another pen drive.
3. Check with genuine OTG cable.
4. Check the USB connection: Perform Phone diagnostics checks through the Samsung Members apps.
Path: Samsung members > Support > Phone diagnostics > USB connection.
5. Clear data of USB settings: To clear the data off the USB, please follow the below steps.
Setting > Apps > Three dots (Appearing at the top right corner) > Show system apps > Search USB Settings > Tap on storage > Clear data of USB Settings.
6. Reset app preferences: Settings > Apps > Three dots (Appearing at the top right corner) > Reset app preferences (It'll reset the permissions of all applications)
7. Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
8. You can reset your device by following the steps.
→ Kindly create a data backup of your device via the SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
 → Remember the Google password before resetting the device because it is required during initial setup.
→ If you do not remember then advise to reset (Forgot password) his/her Google account.
sath3
Hello, I need help with my Samsung Galaxy m52 5g FE. When I connect a USB drive using an OTG adapter, the phone doesn’t seem to detect it. Any advice on how to get this working would be appreciated. Thanks!
