Issue on lockscreen while using lockstar
(Topic created on: 10-01-2025 04:47 PM)
rocket1010
Lock Screen was getting blank  and fluctuate and on tapping it start to work again
2 Comments
Kaustav_Ray
Expert Level 3
Sounds like a display or software glitch. Clear cache in Settings → Apps → Lock Screen, update your phone, and if it persists, consider safe mode or a factory reset. Check for screen damage too.
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
