Issue in Finger Print with Screen Guard in S23
(Topic created on: 05-18-2023 09:23 PM)
raju-83
Hi,
I am unable to use Fingerprint with Screen Protector.
Pls advise which type of Screen guard is useful in Fingerprint sensor.
14 Comments
It depends
But most probably branded screen guards shouldn't interfere with your fingerprint sensor
Even sometimes local screen guards doesn't interfere
I am using local screen guard for my A70 but no problem
prsnt_paul
No dude. A70 has optical fingerprint scanner and S23 has ultrasonic fingerprint scanner. You can use any types of screen guard or protector with A70, but that's not the case if you have a smartphone with ultrasonic fingerprint scanner. You have to use old style screen guards or some high quality tempered glasses. Samsung manufactured screen guards for s23 costs around Rs.800
I know 😅
Just as reference i said
BlackHeart153
Hi,
This happens due to the technology Samsung is using in their phones. It enhances the biometric security but at the cost of clear connection of your finger to the screen.
Most of the clear view screen protectors and some matte finished screen protectors will work. For screen guards and unbreakable glass or something, you need to spend much money. All glue glasses and UV glass works most of the time.
Unfortunately they arenot working in my Samsung Galaxy S20+.
SahajOp
I have said this thousands of time , that in s series phone , remove previous fingerprint before installing the new screen guard and then set up the prints again after installing the screen guard
sk9099
Try to to not dry ur finger...
CODM6567
U can official tempered glass or 500rs uv tempered glass from offline shop.
Or any 200rs good quality tempered glass
All will work. Just an advice, if u buy Samsung official ones, then install it on ur phone by an expert.
Goldychahal
Spigen EZ Fit Tempered Glass Screen Protector Guard for Galaxy S23 (2 Pack) https://amzn.eu/d/i8zOPTk
