DoobyScoo
03-07-2024 06:49 PM (Last edited 03-17-2024 08:20 PM ) in
Galaxy SEdit: It was an Instagram bug, updated Instagram and since then the battery consumption has been normal. Check comments for consumption chart.
I recently updated Instagram (on 5th March) to the latest version on my S24 Ultra and since then it has literally been consuming my battery like a demon.
As you can see the images I have uploaded Battery consumption graph of 1st March, the day (before updating Instagram) of using my phone the way I normally use.
But after updating, you can see the drop in the graph of battery consumption for 6th and 7th and March. Even using the phone the way I normally use, the battery has started to fall below 10%.
Also attaching screenshots of how different apps are consuming the battery. BGMI being a graphic as well processor heavy game consumed only 8%. Facebook, another Meta app consumed only 3% for 30 mins of use.
Whereas Instagram for 2 hour 20 min of use, consumed more than 30%. That clearly shows it's some issue with Instagram as other apps are consuming normal battery.
Also note, the Background usage of Instagram is normal. Nothing off the charts.
Need your help as to understand as to what is causing this? Are any other S24 Ultra users facing this issue? Is there a solution to it? Do I need to do something or Instagram/Android/OneUi will take care of it in the next updated?
Thanks in advance.
13 Comments
- « Previous
- 1
- 2
- Next »
DoobyScoo
03-09-2024 09:44 AM in
5 hours of SOT is very less. But again considering it's just a week old phone, it might be learning your usage patterns and accordingly optimise your battery.
And for Instagram issue, we can just wait for a Software update or App update. I have tried everything except Factory Reset.
sai99999
03-09-2024 10:35 AM in
Okay dooby, will keep you posted after few days
DoobyScoo
03-09-2024 12:40 PM in
Yess sir. I'll update too if I see any changes in drain pattern.
DoobyScoo
03-17-2024 08:22 PM in
The battery consumption now is half of what it used to be before the update.
- « Previous
- 1
- 2
- Next »
