Incorrect PIN Pattern issue on Beta
(Topic created on: 10-28-2019 03:15 PM)
GerryHanny
I was on the One UI Beta and yesterday I got an issue where the phone rejected access to me... It kept on saying that my PIN was incorrect even though it was indeed correct... I reset the device and the problem got worse. I am not able to set a new PIN or Pattern and the device is now left without any secure lock...
I even downgraded to Android P by withdrawing from beta and flashed the OS using ODIN and due to some weird reason the problem follows on Android P as well... It doesn't accept any new PINs or Patterns...
Guys don't downgrade, it does not solve this problem... Another user has confirmed it as well...
And is anyone facing this issue on Android P... Who has not installed the beta????
21 Comments
abhiiceman
oh.. about 2 hrs back i faced this issue and reset the phone to end up with above issue, just now was trying to revert to android P.. thanks for sharing..
GerryHanny
Glad I could help...
Can you please do me a favour and like this post? Thankyou!
https://r2.community.samsung.com/t5/Galaxy-Gallery/Diwali-with-Galaxy/td-p/2625921
Ramgo
I am also facing the same issue on my S10 Plus, even after providing the correct PIN... I am getting wrong PIN message.
Any idea to solve the problem, Please !!!
archit203
Facing the same issue!!
NEED HELP!!
FACTORY Reset the phone is only solution.
Ramgo
Unable to enter the boot menu screen, so factory reset is not an option.
click on volume Up + power + Bixby you would enter the recovery mode. from there you could FACTORY reset.
