10-29-2019 02:39 PM in
Galaxy SThe Android 10 One UI 2.0 beta for the Galaxy S10 series has a critical bug: The device is locking people out by refusing to accept their PIN, password, or pattern. Those who have set up the Remote unlock feature enabled on their phone have been able to use Samsung’s Find My Mobile service to delete all biometrics (password, PIN, pattern, fingerprint and facial recognition), but since the bug causes the device to reject all passwords as incorrect, they have been unable to set a new pattern/PIN/password afterwards.
Unfortunately, not everyone has Remote unlock enabled, and for them, a factory reset and flashing back to Android Pie via Samsung Smart Switch (which deletes all data) is the only solution. It’s not the best solution, of course, and Samsung is yet to officially say anything on the matter. It’s also unclear how the company will fix the problem for those users who don’t want to factory reset their device and are locked out. A regular software update won’t cut it, as a device needs to be unlocked for installing updates.
Take precaution before the issue affects your Galaxy S10 or Note 10
For now, if you’re using the Android 10 beta on a Galaxy S10 or Galaxy Note 10, it’s recommended that you change your lock screen security method to swipe or none until Samsung releases a new beta update or a fix for the issue. You should also enable Remote unlock from the Settings » Biometrics and security » Find My Mobile menu on your phone so you can use Find My Mobile to access it if the issue crops up at any point in the future.
We’ll be keeping a close eye on the situation as it develops, and in the meantime, you can tell us if you have faced the issue on your Galaxy S10 or Galaxy Note 10.
10-29-2019 03:00 PM in
Galaxy S- Mark as New
10-29-2019 05:40 PM in
Galaxy SThank you.
10-29-2019 06:13 PM in
10-29-2019 09:14 PM in
Galaxy Si am locked out
10-29-2019 03:47 PM in
10-29-2019 04:12 PM (Last edited 10-29-2019 04:12 PM ) in
10-29-2019 04:59 PM in
10-29-2019 05:14 PM in
Galaxy SMy S10 is having the problem now . Unable to login to the mobile using Pin. Just now it got restarted. Any idea how to recover it from here or do i need to connect it to system to do factory reset ?
10-29-2019 05:35 PM in
