I recently bought s21 fe snapdragon but I faces display problem 😭
(Topic created on: 02-27-2024 11:51 PM)
sahmin
I recently bought s21 fe snapdragon but I faces display problem 😭 please notice the circle i don't know what name this problem please anyone help me😭😭
19 Comments
Jitender751
Use pixel burn khete h
adminsk
Ya what's the problem
sahmin
https://youtu.be/U6Ubc-1iwOg?si=mfURtftAh4CmKm4g please cheak this video I mean same problem to me 😢
sahmin
Okay broo I will follow your idea but I am so depression for this issue because I recently bought my phone 😢😭
sahmin
Yes same condition 😢
BearXXV
It is called 'Burn In' or 'Image Retention'. If your phone is new or within warranty, you should visit Samsung Service Centre and they will replace your display if it is manufacturing defect and nothing from your end. Also don't send screenshots because it will not get defected pixels in the screenshot. Hope you get your problem solved and find this helpful. 🙏🏼
sahmin
Yes bro new phone just 1 month old
BearXXV
Yes, you should visit Samsung Service Centre. They will replace your display and battery for free.
KumarUjjawal
remove your setting from dark mode.. then check.
KumarUjjawal
if it is then visit service center
