I'm facing a brightness problem in s23 ultra
(Topic created on: 05-03-2023 06:01 PM)
Amey1503
From today's afternoon for some reason the brightness is coming low in bright also
I'm not able to see the screen
Can anyone tell me what happened to my phone ?
9 Comments
Amey1503
Auto brightness pe hai fir bhi thoda darker hai display
Aisa kyu ho rha hai koi bata skta hai to pls reply
Goldychahal
check extra dim ...
Amey1503
Off hai
Nevilpatel02
Go to nearby samsung service center
Amey1503
Restart bhi kia & settings bhi reset ki
Sid_Karna
Did the phone heat too much? In that case the display will automatically reduce brightness.
ooypawan
Yes ...brightness verry dim
cs-member11
Dear Samsung Member,
We acknowledge your query and apologize for the same. We request that you kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
ooypawan
Brightness is not working properly and then I will send you the screenshot and video plis give me what's up number
