I know how to fix battery drain issue
(Topic created on: Friday)
Parth_Shanker
You want to know then message in comment or message be personally.
No promotion no extra app.
200% guarantee this will work
KunteAmith
S22ultra
hentk9
Exactly.. munafa khor
Syed29
Everyone needs its brother, who doesn't want their battery life to be good?
Please do share
Parth_Shanker
Your device
Parth_Shanker
Your model
mrsayantandas
Faltu bakwas
Wodehouse
Simple steps to save battery at the cost of sacrificing luxury
1 Enable Power saver
2 Enable performance mode light
3 Enable adaptive power saving instead of basic
4 Enable adaptive brightness
5 Disable AOD
6 Enable extra dim
7 Change display to natural
8 Screen time out to 30 secs (system default)
9 Record videos in FHD
10 Restrict gaming to HD or FHD and slower frame rate
11 Switch to dark mode
12 Disable near by device scanning
13 Disable WiFi scanning
14 If 5G is unavailable change network to LTE/3G/2G
15 Allow the battery to drain completely and recharge,say once a month.
16 Enable auto restart
17 Run device care
18 Disable apps running in background.
19 Disable RAMplus if you dont use memory intensive apps and do heavy multi tasking. Available RAM usually around 2 to 3 Gb is more than sufficient for normal tasks.
20 Uninstall bloat ware that came with your phone,eg. Spotify,LinkedIn etc.
You can mix match the steps above and arrive at a usage based on your needs.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
CVRocksss
Batao
naviaz
