How will you rate my S23 (256) battery performance in different scenarios?
(Topic created on: 06-20-2024 11:14 AM)
Victor12
All of these are on mobile data. All settings are at max unless mentioned in the screenshot.
To summarise I can get 6 hours of SOT on heavy usage.
Average SOT is 7-8 hours with regular usage.
I can strech it upto 9-10 hours of I use low settings. Also I charger battery only upto 80 and don't drain less than 20% unless I am travelling so charging is also satisfactory.
11 Comments
Jsnpreet
🤷🤷good
Sáyân15
Victor12
So S23 does give a full day of battery
Sáyân15
Easily...
sracuka
You google play services background battery drain
sracuka
Do you have only one google account
Victor12
No I have multiple accounts
sracuka
So what is the amount of battery consumed by google play services in your device can you share the screeenshot
sracuka
And please tap on the google play services in ' Since last charge' section and check what is the wake up and wakeup lock mine crosses 70
