How to enable swipe up gestures for multi window s24ultra - FREEZED
(Topic created on: 05-02-2025 08:21 AM)
Ram_89_S24U
The swipe up gesture for multi window is frezzed and not working, it was actually easy and handy to use that ! Is there any option.. tried with Navstar but still not working.
#samsung, #s24ultra #gestures #settings #multiwindow
2 Comments
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the same video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
Ram_89_S24U
Hi thanks for the swift response, shall do it ASAP
