How to de-register and re- register my device
(Topic created on: 07-16-2024 11:57 AM)
anandVivek22
I accidently registered my device with wrong configuration and now i am unable to re register it in correct config. I even unregistered it but it still shows "device already registered" when I try to do so. Help!
3 Comments
MR_PRIME
Do a call with customer care that's only the option they will guide you remotely my friend.
Plz Accept solution clicking on 3dot right side nd Do follow for Regular Updates.
Màhmudul
Connect to Samsung customer support and tell them the issue.i hope they will solve it
cs_member10
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share screenshots and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
