How to connect my pc using Bluetooth
(Topic created on: 11-05-2022 06:24 PM)
Manishivaultra
Hi, how to connect my pc and. S20FE mobile through Bluetooth  my windows 11  desktop
I also connect Bluetooth dongle. Can't connect help me guys.
3 Comments
Maverik666
Search for connect app in windows. Then follow the instructions
Samsung_OneUi
Don't worry bro. just follow my steps
1. Open your laptop turn on bluetooth from toggle.
2. go to settings.
3. Select bluetooth and devices option
4. Go to add device
5. Select Bluetooth option
6. Turn on bluetooth of your phone
...if you want to use internet from your s20 fe please go to connections and select mobile hotspot and tethering option and then select bluetooth tethering from your device. if you find the solution please go to 3 dots of my comment and select accept solution. thankyou 👍 🤝
Thank you
