How to Use Physical SIM for Calls and eSIM for Data on Samsung S24+?
(Topic created on: 01-23-2025 04:09 AM)
shadowsadik
I am currently using the Samsung S24+ and want to configure my phone so that my physical SIM is used for phone calls and the eSIM is used for mobile data. However, I can’t find any option to set this up. Can someone guide me on how to do this? Thank you!
10 Comments
ayuspande
you can configure in quick panel settings Screenshot_20250123_054309_Samsung Members_1000006336_1737591223.png
shadowsadik
Wodehouse
Go to settings > connections > SIM manager > Preferred SIMs. Tap SIM one and choose the option. Similarly tap eSIM and choose the option. Please see screen shot. Or, pull down quick panel and select the option. See 2nd screen shot
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊 1737591471912.jpg1737591613552.jpg
shadowsadik
I do not have this option, what settings i should change to get this option?1737603183040.jpg
shadowsadik
Wodehouse
My Robi is your 1st SIM. Select My Robi. Disable eSIM and see what it shows.
shadowsadik
Wodehouse
Your phone number country code does not look India.
I suggest you get in touch with local Samsung care.
shadowsadik
