01-13-2026 08:59 PM in
Galaxy SSolved! Go to Solution.
01-13-2026 10:09 PM in
Galaxy S- Mark as New
01-13-2026 10:10 PM in
01-14-2026 05:45 AM in
01-14-2026 05:46 AM in
01-14-2026 10:11 AM in
Galaxy SDear Samsung Member,
● Disable the data saver: Path: Settings > Connections >Data usage > Data saver > Disable data saver (if enabled).
● Reset network settings: Path: Settings > General Management > Reset > Reset network settings.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
● Update device software (If available): Settings > Software update > Download and install > Checking for software update > Software update available > Download > Downloading updates > Install now.
3. If you do not remember, then advise to reset (Forgot password) your Google account.
Path: Settings> General Management>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
01-25-2026 11:53 PM in
