Hitting Problem
(Topic created on: 05-17-2025 08:56 PM)
SRUltra
One ui7 update ke baad Mera S23 ultra device bahat jada hit ho raha.30/40 minutes normal use karne se hi hit ho raha.Itna mehenga ph or aisa agr problem hoga to kon purchase karega? Plz solve this issue quickly. Ye feedback concerned team ko vejo jaldi.Otherwise social media ke har platform par continuously negative review dalta hi rahunga.
8 Comments
Mani4
clear cache partition, if not working, format the device
sudhirkr7
kaise clear hota hai
Mani4
boot device in recovery mode, then clear cache partition
sudhirkr7
mere s23 ultra me bhi same heating problem hai
sudhirkr7
recovery mode me kaise boot krte hain aur wapas kaise llate hain... data lose hone ka dar to nahi hai na
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
1. Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. If the issue is still not been resolved, Reset the device:
IMPORTANT:
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send).
