Help post
(Topic created on: 05-09-2026 04:48 PM)
smc89
Where is samsung gallery in this app
5 Comments
OMKALEESH
You ill be able to see in the below keyboard
OMKALEESH
Like this... if you find this helpful please accept my solution 1778327953766.jpg
Prottay
That's the tag section
Prottay
While posting, tap in forum and then 'Galaxy Gallery'. After that, your photos will be posted on the galaxy gallery section where it can get more attention.
If this helped please click on the 3 dots and then press 'Accept Solution' to keep me motivated.😊1778330130614.jpg1778330130657.jpg
cs_member10
Dear Samsung Member,
We request you kindly share the log file and elaborate on your concern in detail. Also, share video clips and images for better understanding. This will help us to investigate further and resolve the issue.
Path share log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.)
