Help help help please
(Topic created on: 10-25-2024 12:18 AM)
Ziyani
I have samsung s20 fe 5g AT&T I update it and then 5g signals not coming what can I doo
10 Comments
Vikasofficial
Expert Level 3
Before update come 5g signal ??
Which simcard you use ?
Ziyani
Yes 5g signal showing then but I update it now not working 😕
Airtel
Ziyani
Any solution
Vikasofficial
Expert Level 3
Check Network mode or restart mobile or once change sim card slot then reply me
Ziyani
I do almost everything except factory reset
rajba
Kitne रूपी doge
Osho_Niraj
Worse brand samsung...
Asbar
Sell the samsung phone you are having and also kindly uninstall members app.. kindly respect your own choice
cs_member10
Dear Samsung Member,
As per your concern, we would request you to kindly visit this mentioned link to resolve your issues.
● Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
