Help ! Split screen
(Topic created on: 08-05-2024 11:36 AM)
nikes21fe
Hi Samsung,
I am facing a split screen on my galaxy S21 fe after the July security update was pushed.
Please help in fixing this issue.
Thanks
NikeS21fe
2 Comments
Oldy4756
Screenshot? Or if it's doesn't come in Ss then take photo from other device. Or front camera using mirror
cs_member10
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
