Heating problem
(Topic created on: 06-02-2026 03:21 PM)
shaikh97
After update, phone getting heat using any app.
9 Comments
shriii41
After may security update?
shaikh97
UI & security
srinivaskamsani
Which device,
What update?
After one ui 8.5 or after may update..
shaikh97
Previous and 8.5 May update.. Both
Prabhat07_
What about charging speed??
shaikh97
25v & 45v
Heating both time
Prabhat07_
Speed decrease or not ??
shaikh97
Charging speed is same, no issue
cs_member10
Dear Samsung Member,
1. Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Update software: Go to Settings > Software update > Download and install > Checking for software update > Software update available > Tap on Download > Downloading updates > Tap on Install now.
8. If the issue is still not been resolved, Reset the device:
IMPORTANT:
• Kindly create data backup of your device via SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
